sddsplot filename bug on Fedora18 - 64 bit
yjkim
Post by yjkim » 25 Apr 2013, 17:15
Dear Dr. Soliday,
After downloading your new mpl_motif and installation of motif, we can use sddsplot on Fedora18 - 32 bit without any problem.
However, in the case of Fedora18 - 64 bit, we can not use figure saving function of sddsplot properly.
We can not change spelling or file name to save EPS file or PNG file if we would like to save
output of sddsplot under Fedora18 - 64 bit.
You can check it easily with follow steps:
sddsplot panel -> File -> Setup -> Print File -> try to change the default file name (mpl.ps)
or from
File -> Setup -> Save File -> try to change the default file name (~/mpl.png)
Please would you check this problem, and upload an updated version of sddsplot to solve the filename issue?
Actually, I reported this bug from Fedora15, but there was no action from you or Dr. Borland yet.
Sincerely yours,
Yujong Kim
Re: sddsplot filename bug on Fedora18 - 64 bit
Post by soliday » 26 Apr 2013, 11:20
Okay I now have a natively built version of mpl_motif for Fedora 18 64bit.
http://www.aps.anl.gov/asd/oag/download ... .f18.64bit
Install this the same way you installed the previous 32 bit version.
I will have to come up with a better solution for distributing mpl_motif on the wide range of linux operating systems. I thought that by making it a static executable that I had solved the problem but apparently that wasn't enough.
yjkim
Post by yjkim » 29 Apr 2013, 06:19
Dear Dr. Soliday,
Thank you so much for your quick help!
We will try to use the uploaded mpl_motif for Fedora 18 - 64 bit.
Sincerely yours,
Yujong Kim
