in mode r: No such file or directory
Zeus
Post by Zeus » 05 Mar 2012, 02:23
I have just installed Elegant and I can’t run the examples. I get the following message when I try any example:
This is elegant 25.0.2, Mar  1 2012, by M. Borland, W. Guo, V. Sajaev, Y. Wang, Y. Wu, and A. Xiao.
Link date: Mar  1 2012 10:13:49
ensure the RPN_DEFNS environment variable is set
I have installed elegant-25.0.2-1.x86_64.rpm and SDDSEpicsToolKit-2.9-1.x86_64.rpm in an openSUSE 11.2. I think the environment variable RPN_DEFNS is well defined in my “.bashrc” file:
export RPN_DEFNS=~/.defns.rpn
Did something similar happen to somebody? Can you help me with that?
Many thanks,
Zeus
Re: in mode r: No such file or directory
Post by soliday » 05 Mar 2012, 10:10
Can you run:
ls -l $RPN_DEFNS
and verify that the file exists. If not, you can download it from:
http://www.aps.anl.gov/Accelerator_Syst ... =defns.rpn
ywang25
Post by ywang25 » 05 Mar 2012, 10:16
You can also try
elegant -rpnDefns=<filename>
in the command line.
Yusong
Zeus
Post by Zeus » 06 Mar 2012, 01:12
Yusong and soliday, thanks for your fast answer,
Doing “ls” of the environment variable does not find the file. Yusong suggestion worked, however we finally solved the problem by redoing from scratch the ".batchrc" file. Maybe, editing it from windows had been the problem... I’m sorry, I’m just a “from time to time” Linux user.
Cheers,
Zeus.
