Moderators: cyao, soliday
MDP
Post
by MDP » 06 Jul 2010, 08:36
Hello,
I just started with elegant and I have some problems to run it on Ubuntu 10.04. I tried to execute some of the examples from the web page but some of them didn't work and I got the message:
Code: Select all
unable to open FM1#1.R16 2.898284e-01 1e-5 sene in mode r: No such file or directory
ensure the RPN_DEFNS environment variable is set
Error:
Unable to open file "run1.mat" for reading (SDDS_InitializeInput)
Could it be that I just have to set a path to the named variables? Then, the next problem would be that I don't know how to do that...
May one of you help me with this problems?
Thank you in advance!
Cheers,
MDP
PS: The cwiggler1 example run without any problems...
soliday
Post
by soliday » 06 Jul 2010, 09:23
Which example are you trying to run. It looks like you might not have the environment variable RPN_DEFNS set. You have to download defns.rpn from:
http://www.aps.anl.gov/Accelerator_Syst ... /defns.rpn
and then set the RPN_DEFNS environment variable to point to it. If you are in a bash shell the command would look like:
export RPN_DEFNS=/home/MDP/defns.rpn
If you are in a csh or tcsh shell the command would look like:
setenv RPN_DEFNS /home/MDP/defns.rpn
MDP
Post
by MDP » 06 Jul 2010, 09:35
Hi soliday,
thank you for your help! Now, it works perfectly!
It was the betaMatching example that didn't run.
Thanks again.
Cheers, MDP
