Installation on Fedora 34
Posted: 20 Dec 2021, 03:29
I'm trying to install Elegant on Fedora 34, which is mounted on VMware Workstation 16 Player.
During the Build-AOP-RPMs script, I got error messages;
Building SDDS RPM package. This may take a minute.
Building target platforms: x86_64
Building for target x86_64
install: cannot stat 'mecho': No such file or directory
error: Bad exit status from /var/tmp/rpm-tmp.5KNeWR (%install)
New RPM file in ~/rpmbuild/RPMS/x86_64
Cleaning up
Building SDDS DEV RPM package. This may take a minute.
install: cannot stat 'base.h': No such file or directory
error: Bad exit status from /var/tmp/rpm-tmp.Kqz4mj (%install)
Cleaning up
Building SDDS EPICS RPM package. This may take a minute.
no files matched glob pattern "/home/okayasu/elegant/oagsoftware/epics/extensions/bin/linux-x86_64/*"
while executing
"glob $oagsoftware/epics/extensions/bin/$env(EPICS_HOST_ARCH)/* "
invoked from within
"if {$Build(SDDSEPICS)} {
puts "Building SDDS EPICS RPM package. This may take a minute."
eval exec $sudo wget -q https://ops.aps.anl.gov/..."
(file "Build-AOP-RPMs.tcl" line 1493)
Refering the previous post;
viewtopic.php?f=11&t=1203&p=4975&hilit=mecho#p4975
I individually installed SDDSToolkit, but it did not work.
Also, some post suggests that installation directory should be somewhere under the home directory,
not network mounted drive.
Thus I tried this way, but did not solve this issue.
If someone know the solution, please tell me.
Also any suggestions are very welcome.
Best regards,
Okayasu
Cleaning up
Cleaning up
while executing
invoked from within
Best regards,
Okayasu
