install sddstoolkit at RHEL 4
Moderators: cyao, soliday
Post Reply
ding
Post by ding » 15 Apr 2010, 13:35
Hello,
I tried to install the elegant in another machine with RHEL4.
for sddstoolkit. the right file I should download is SDDSToolKit-2.6-1.fc4.i386.rpm , which is for RHEL4. But it needs a library file "libreadline.so.5 ". At RHEL4, the default is "libreadline.so.4 ". I tried making a symbolic link to rename the "libreadline.so.4 " as "libreadline.so.5" but not work. What is the correct way to do?
Thanks,
Yuantao
soliday
Re: install sddstoolkit at RHEL 4
Post by soliday » 15 Apr 2010, 13:59
I'm look into fixing this for the next release. As for installing the one you have, the symlink was the correct thing to do. Next when you run rpm you have to add the -nodeps option.
ding
Post by ding » 15 Apr 2010, 17:21
thanks. it works.
Yuantao :D
Post Reply
