SDDS Installation
Moderators: cyao, soliday
Post Reply
fabioluneli
SDDS Installation
Post by fabioluneli » 10 Feb 2022, 10:36
Hello!
I am trying to install SDDS on Windows 10. But always that i tried an error appears saying that i need to try again. Anyone knows thr problem?.
Thank you!
soliday
Re: SDDS Installation
Post by soliday » 10 Feb 2022, 11:17
I just tested it on two different Windows 10 machines. I was able to install it on both. Can you send a screenshot of the error message you are seeing?
fabioluneli
Post by fabioluneli » 10 Feb 2022, 19:49
Here is the error that appears... It is attached.
Thank you!
soliday
Post by soliday » 11 Feb 2022, 11:46
Perhaps it is an permission related problem. Try installing the software with an account that has administrator privileges.
fabioluneli
Post by fabioluneli » 11 Feb 2022, 17:31
Actually i haver already tried, i am using the main user.
soliday
Post by soliday » 14 Feb 2022, 23:19
I updated the packaging software to the newest version in case there was an issue they may have fixed. Let me know if you are able to install the version at the following link:
https://ops.aps.anl.gov/downloads/SDDS_ ... 4-test.msi
fabioluneli
Post by fabioluneli » 01 Mar 2022, 17:41
Hello, thank you! I have already solved SDDS problem! The problem was installing one partition over another.
Now i am having problem at extracting the Elegant file using cygwin. Looks like cygwin isn't locating the paste, and when i tried "ls" command only two folders appears "bin" and "tmp". Any tip?
Thank you!
Post Reply
