compile genesis_mpi in CentOS
Moderators: cyao, soliday
Post Reply
yiding
Post by yiding » 08 Jan 2020, 03:15
I'm trying to compile the mpi edition of GENESIS 2.0 source code in CentOS7.
I have modified the Makefile of genesis a littie:
# GENESIS makefile
SOURCE= main.f check.f diagno.f esource.f field.f incoherent.f \
math.f partsim.f pushp.f loadbeam.f loadrad.f magfield.f \
tdepend.f track.f string.f rpos.f scan.f source.f stepz.f \
timerec.f initrun.f input.f output.f mpi.f sdds.f
# output.f \
# LIB= -lmdbmth -lSDDS1 -lmdblib -lz
#OBJECTS =$(SOURCE:.f=.o)
#ifeq ($(EPICS_HOST_ARCH),win32-x86)
#COMPILER = ifort
#else
#COMPILER = g77
#endif
COMPILER = mpif77
# executable name
#EXECUTABLE = GENESIS
EXECUTABLE = genesis_mpi
ifeq ($(EPICS_HOST_ARCH),linux-x86_64)
LIB_DIR = $(HOME)/epics/extensions/lib/linux-x86_64
SDDS_FORTRAN_WRAPPER = $(HOME)/epics/extensions/src/SDDS/fortran/O.linux-x86_64/fortran_wrapper.o
LDFLAGS=$(SDDS_FORTRAN_WRAPPER) -Wl,-Bstatic -L$(LIB_DIR) -lmdbmth -lSDDS1 -lmdblib -lz -static-libgcc -lc
CFLAGS=-Wl,--build-id -O2 -ffixed-line-length-132 -Wall -fno-second-underscore -Wno-globals -Wimplicit -Wno-unused
endif
# targets
else
GENESIS: $(SOURCE)
$(COMPILER) -g -w -O -Wall $(CFLAGS) -o $(EXECUTABLE) $(SOURCE) $(LDFLAGS)
@echo ' ******* end of linking ****** '
endif
When I run the make command, I've got the following error message.
mpif77 -g -w -O -Wall -Wl,--build-id -O2 -ffixed-line-length-132 -Wall -fno-second-underscore -Wno-globals -Wimplicit -Wno-unused -o genesis_mpi main.f check.f diagno.f esource.f field.f incoherent.f math.f partsim.f pushp.f loadbeam.f loadrad.f magfield.f tdepend.f track.f string.f rpos.f scan.f source.f stepz.f timerec.f initrun.f input.f output.f mpi.f sdds.f /home/liyd/epics/extensions/src/SDDS/fortran/O.linux-x86_64/fortran_wrapper.o -Wl,-Bstatic -L/home/liyd/epics/extensions/lib/linux-x86_64 -lmdbmth -lSDDS1 -lmdblib -lz -static-libgcc -lc
f951: warning: command line option ‘-Wimplicit’ is valid for C/ObjC but not for Fortran [enabled by default]
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__libc_sigaction':
(.text+0x8a50): multiple definition of `__libc_sigaction'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(sigaction.o):(.text+0x20): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__libc_fsync':
(.text+0x8160): multiple definition of `__libc_fsync'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(fsync.o):(.text+0x0): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__connect_nocancel':
(.text+0x7e29): multiple definition of `__connect_nocancel'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(connect.o):(.text+0x9): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__libc_fcntl':
(.text+0x7ca0): multiple definition of `__libc_fcntl'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(fcntl.o):(.text+0xa0): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__fsync_nocancel':
(.text+0x8169): multiple definition of `__fsync_nocancel'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(fsync.o):(.text+0x9): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `_IO_funlockfile':
(.text+0x89f0): multiple definition of `_IO_funlockfile'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(funlockfile.o):(.text+0x0): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__libc_nanosleep':
(.text+0x8280): multiple definition of `__libc_nanosleep'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(nanosleep.o):(.text+0x0): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__read':
(.text+0x7b40): multiple definition of `__libc_read'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(read.o):(.text+0x0): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__open_nocancel':
(.text+0x82e9): multiple definition of `__open_nocancel'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(open.o):(.text+0x9): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__lseek_nocancel':
(.text+0x81c9): multiple definition of `__lseek_nocancel'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(llseek.o):(.text+0x9): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__read_nocancel':
(.text+0x7b49): multiple definition of `__read_nocancel'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(read.o):(.text+0x9): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `send':
(.text+0x7ff0): multiple definition of `__libc_send'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(send.o):(.text+0x0): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__libc_close':
(.text+0x7ba0): multiple definition of `__libc_close'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(close.o):(.text+0x0): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__open':
(.text+0x82e0): multiple definition of `__libc_open'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(open.o):(.text+0x0): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__write_nocancel':
(.text+0x7ae9): multiple definition of `__write_nocancel'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(write.o):(.text+0x9): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `waitpid':
(.text+0x8580): multiple definition of `__libc_waitpid'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(waitpid.o):(.text+0x0): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__close_nocancel':
(.text+0x7ba9): multiple definition of `__close_nocancel'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(close.o):(.text+0x9): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__fcntl_nocancel':
(.text+0x7c00): multiple definition of `__fcntl_nocancel'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(fcntl.o):(.text+0x0): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__llseek':
(.text+0x81c0): multiple definition of `__libc_lseek'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(llseek.o):(.text+0x0): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `sigaction':
(.text+0x8c40): multiple definition of `__sigaction'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(sigaction.o):(.text+0x210): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__errno_location':
(.text+0x9ed0): multiple definition of `__errno_location'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(errno-loc.o):(.text+0x0): first defined here
(.text+0x89f0): multiple definition of `__funlockfile'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__lll_lock_wait_private':
(.text+0x7920): multiple definition of `__lll_lock_wait_private'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(libc-lowlevellock.o):(.text+0x0): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__write':
(.text+0x7ae0): multiple definition of `__libc_write'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(write.o):(.text+0x0): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__nanosleep_nocancel':
(.text+0x8289): multiple definition of `__nanosleep_nocancel'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(nanosleep.o):(.text+0x9): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `connect':
(.text+0x7e20): multiple definition of `__libc_connect'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(connect.o):(.text+0x0): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `__lll_unlock_wake_private':
(.text+0x79d0): multiple definition of `__lll_unlock_wake_private'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(libc-lowlevellock.o):(.text+0x30): first defined here
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libpthread.a(libpthread.o): In function `raise':
(.text+0x88e0): multiple definition of `raise'
/usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libc.a(raise.o):(.text+0x0): first defined here
/usr/local/mpich2/lib/libmpich.a(tcp_init.o): In function `MPID_nem_tcp_get_business_card':
tcp_init.c:(.text+0x3e3): warning: Using 'gethostbyname' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
/home/liyd/epics/extensions/lib/linux-x86_64/libSDDS1.a(SDDS_lzma.o): In function `lzma_open':
/home/liyd/epics/extensions/src/SDDS/SDDSlib/O.linux-x86_64/../SDDS_lzma.c:61: undefined reference to `lzma_easy_encoder'
/home/liyd/epics/extensions/src/SDDS/SDDSlib/O.linux-x86_64/../SDDS_lzma.c:55: undefined reference to `lzma_auto_decoder'
/home/liyd/epics/extensions/lib/linux-x86_64/libSDDS1.a(SDDS_lzma.o): In function `lzma_close':
/home/liyd/epics/extensions/src/SDDS/SDDSlib/O.linux-x86_64/../SDDS_lzma.c:102: undefined reference to `lzma_end'
/home/liyd/epics/extensions/src/SDDS/SDDSlib/O.linux-x86_64/../SDDS_lzma.c:84: undefined reference to `lzma_code'
/home/liyd/epics/extensions/src/SDDS/SDDSlib/O.linux-x86_64/../SDDS_lzma.c:94: undefined reference to `lzma_end'
/home/liyd/epics/extensions/lib/linux-x86_64/libSDDS1.a(SDDS_lzma.o): In function `lzma_read':
/home/liyd/epics/extensions/src/SDDS/SDDSlib/O.linux-x86_64/../SDDS_lzma.c:133: undefined reference to `lzma_code'
/home/liyd/epics/extensions/lib/linux-x86_64/libSDDS1.a(SDDS_lzma.o): In function `lzma_gets':
/home/liyd/epics/extensions/src/SDDS/SDDSlib/O.linux-x86_64/../SDDS_lzma.c:180: undefined reference to `lzma_code'
/home/liyd/epics/extensions/lib/linux-x86_64/libSDDS1.a(SDDS_lzma.o): In function `lzma_write':
/home/liyd/epics/extensions/src/SDDS/SDDSlib/O.linux-x86_64/../SDDS_lzma.c:227: undefined reference to `lzma_code'
/home/liyd/epics/extensions/lib/linux-x86_64/libSDDS1.a(SDDS_lzma.o): In function `lzma_puts':
/home/liyd/epics/extensions/src/SDDS/SDDSlib/O.linux-x86_64/../SDDS_lzma.c:269: undefined reference to `lzma_code'
/home/liyd/epics/extensions/lib/linux-x86_64/libSDDS1.a(SDDS_lzma.o): In function `lzma_putc':
/home/liyd/epics/extensions/src/SDDS/SDDSlib/O.linux-x86_64/../SDDS_lzma.c:311: undefined reference to `lzma_code'
collect2: error: ld returned 1 exit status
make: *** [GENESIS] Error 1
I wonder what I can do to compile it correctly.
Thanks very much,
--Yiding Li
soliday
Re: compile genesis_mpi in CentOS
Post by soliday » 08 Jan 2020, 11:59
Here is the current Makefile in SVN with your two changes for the compiler and the executable:
Code: Select all
# GENESIS makefile
# output.f  \
#  executable name
COMPILER = ifort
else
ifeq ($(MPI),1)
COMPILER = /head/home/backup/lustre/3rdPartySoftware/mvapich2-2.3b/bin/mpif77
#COMPILER = /lustre/3rdPartySoftware/mvapich2-1.9rc1/bin/mpif77
EXECUTABLE = GENESIS_mvapich2-2.3b
COMPILER = mpif77
else
COMPILER = gfortran
endif
endif
ifeq ($(HOST_ARCH),solaris)
LIB_DIR = $(HOME)/epics/extensions/lib/solaris-sparc
SDDS_FORTRAN_WRAPPER = $(HOME)/epics/extensions/src/SDDS/fortran/O.solaris-sparc/fortran_wrapper.o
LDFLAGS=$(SDDS_FORTRAN_WRAPPER) -L$(LIB_DIR) -lmdbmth -lSDDS1 -lmdblib -lz
CFLAGS=-O2 -ffixed-line-length-132 -Wall -fno-second-underscore -Wno-globals -Wimplicit -Wno-unused
endif
ifeq ($(EPICS_HOST_ARCH),linux-x86)
SDDS_FORTRAN_WRAPPER = $(HOME)/epics/extensions/src/SDDS/fortran/O.linux-x86/fortran_wrapper.o
CFLAGS=-m32 -O2 -ffixed-line-length-132 -Wall -fno-second-underscore -Wno-globals -Wimplicit -Wno-unused
endif
ifeq ($(MPI),1)
LDFLAGS=$(SDDS_FORTRAN_WRAPPER) -L$(LIB_DIR) -lmdbmth -lSDDS1 -lmdblib -llzma -lz -lc
else
LDFLAGS=$(SDDS_FORTRAN_WRAPPER) -Wl,-Bstatic -L$(LIB_DIR) -lmdbmth -lSDDS1 -lmdblib -llzma -lz -static-libgcc -lc
endif
CFLAGS=-m64 -O2 -ffixed-line-length-132 -Wall -fno-second-underscore -Wno-globals -Wimplicit -Wno-unused
CFLAGS=-m64 -O2 -ffixed-line-length-132 -Wall -fno-second-underscore -Wno-unused
endif
# targets
OBJ =.obj
OBJNAMES = main$(OBJ) check$(OBJ) diagno$(OBJ) esource$(OBJ) field$(OBJ) incoherent$(OBJ) \
 math$(OBJ) partsim$(OBJ) pushp$(OBJ) loadbeam$(OBJ) loadrad$(OBJ) magfield$(OBJ) \
 tdepend$(OBJ) track$(OBJ) string$(OBJ) rpos$(OBJ) scan$(OBJ) source$(OBJ) stepz$(OBJ) \
 timerec$(OBJ) initrun$(OBJ)  input$(OBJ) output$(OBJ) mpi$(OBJ) sdds$(OBJ)
main$(OBJ):
	ifort /compile_only /threads /libs:dll main.f
check$(OBJ):
	ifort /compile_only /threads /libs:dll check.f
diagno$(OBJ):
	ifort /compile_only /threads /libs:dll diagno.f
esource$(OBJ):
	ifort /compile_only /threads /libs:dll esource.f
field$(OBJ):
	ifort /compile_only /threads /libs:dll field.f
incoherent$(OBJ):
	ifort /compile_only /threads /libs:dll incoherent.f
math$(OBJ):
	ifort /compile_only /threads /libs:dll math.f
partsim$(OBJ):
	ifort /compile_only /threads /libs:dll partsim.f
pushp$(OBJ):
	ifort /compile_only /threads /libs:dll pushp.f
loadbeam$(OBJ):
	ifort /compile_only /threads /libs:dll loadbeam.f
loadrad$(OBJ):
	ifort /compile_only /threads /libs:dll loadrad.f
magfield$(OBJ):
	ifort /compile_only /threads /libs:dll magfield.f
tdepend$(OBJ):
	ifort /compile_only /threads /libs:dll tdepend.f
track$(OBJ):
	ifort /compile_only /threads /libs:dll track.f
string$(OBJ):
	ifort /compile_only /threads /libs:dll string.f
rpos$(OBJ):
	ifort /compile_only /threads /libs:dll rpos.f
scan$(OBJ):
	ifort /compile_only /threads /libs:dll scan.f
source$(OBJ):
	ifort /compile_only /threads /libs:dll source.f
stepz$(OBJ):
	ifort /compile_only /threads /libs:dll stepz.f
timerec$(OBJ):
	ifort /compile_only /threads /libs:dll timerec.f
initrun$(OBJ):
	ifort /compile_only /threads /libs:dll initrun.f
input$(OBJ):
	ifort /compile_only /threads /libs:dll input.f
output$(OBJ):
	ifort /compile_only /threads /libs:dll output.f
mpi$(OBJ):
	ifort /compile_only /threads /libs:dll mpi.f
sdds$(OBJ):
	ifort /compile_only /threads /libs:dll sdds.f
#/F80000000
GENESIS: $(OBJNAMES)
	$(COMPILER) /exe:$(EXECUTABLE).exe /threads /libs:dll /F80000000 \
	$(OBJNAMES) \
	c:\\epics\\extensions\\src\\SDDS\\fortran\\O.$(EPICS_HOST_ARCH)\\fortran_wrapper.obj \
	/link /incremental:no /opt:ref /release \
	c:\\epics\\extensions\\lib\\$(EPICS_HOST_ARCH)\\mdbcommon.lib \
	c:\\epics\\extensions\\lib\\$(EPICS_HOST_ARCH)\\matlib.lib \
	c:\\epics\\extensions\\lib\\$(EPICS_HOST_ARCH)\\fftpack.lib \
	c:\\epics\\extensions\\lib\\$(EPICS_HOST_ARCH)\\SDDS1.lib \
	c:\\epics\\extensions\\lib\\$(EPICS_HOST_ARCH)\\rpnlib.lib \
	c:\\epics\\extensions\\lib\\$(EPICS_HOST_ARCH)\\namelist.lib \
	c:\\epics\\extensions\\lib\\$(EPICS_HOST_ARCH)\\mdbmth.lib \
	c:\\epics\\extensions\\lib\\$(EPICS_HOST_ARCH)\\mdblib.lib \
	c:\\epics\\extensions\\lib\\$(EPICS_HOST_ARCH)\\z.lib
else
GENESIS: $(SOURCE)
	@cp mpi.f.single mpi.f
	@cp mpif.h.single mpif.h
GENESIS_mvapich2-2.3b: $(SOURCE)
	@cp mpi.f.multi mpi.f
	@rm mpif.h
endif
clean:
	rm -f *~
	rm -f *.o *.obj genesis GENESIS GENESIS_mpi
install:
	cp ./$(EXECUTABLE) ~/bin/
single:
multi:
	rm mpif.h
When I run it I get:
Code: Select all
> make MPI=1
mpif77 -g -w -O -Wall -m64 -O2 -ffixed-line-length-132 -Wall -fno-second-underscore -Wno-unused -o genesis_mpi main.f check.f diagno.f esource.f field.f incoherent.f math.f partsim.f pushp.f loadbeam.f loadrad.f magfield.f tdepend.f track.f string.f rpos.f scan.f source.f stepz.f timerec.f initrun.f  input.f output.f mpi.f sdds.f /home/phoebus/SOLIDAY/epics/extensions/src/SDDS/fortran/O.linux-x86_64/fortran_wrapper.o -L/home/phoebus/SOLIDAY/epics/extensions/lib/linux-x86_64 -lmdbmth -lSDDS1 -lmdblib -llzma -lz -lc
yiding
Post by yiding » 09 Jan 2020, 20:10
Thank you for your timely help.
This makefile seems quite different from the one I downloaded from here:
I compiled genesis2.0_mpi successfully by using the new Makefile, and It works properly in single-thread.
However, when I run it with mpiexec, the error message comes:
Code: Select all
mpiexec -np 20 /home/admin/oagsoftware/oag/apps/src/genesis/genesis2.0_mpi
At line 254 of file input.f (unit = 5, file = 'stdin')
Fortran runtime error: End of file
Genesis 2.0 has begun execution
(Version 1.0 Unix)
Please enter input file name
(Version 1.0 Unix)
(Version 1.0 Unix)
(Version 1.0 Unix)
(Version 1.0 Unix)
(Version 1.0 Unix)
(Version 1.0 Unix)
(Version 1.0 Unix)
(Version 1.0 Unix)
(Version 1.0 Unix)
(Version 1.0 Unix)
(Version 1.0 Unix)
(Version 1.0 Unix)
(Version 1.0 Unix)
(Version 1.0 Unix)
(Version 1.0 Unix)
(Version 1.0 Unix)
(Version 1.0 Unix)
(Version 1.0 Unix)
(Version 1.0 Unix)
lcls_wake_CU.in
SDDS output [Y]es/[N]o
n
***  Input-warning: no harmonic output above NHARM
***  Warning: Size of history file [Mbytes]:1442
Slice     1: Simulation  10% completed.
Slice     1: Simulation  20% completed.
Slice     1: Simulation  30% completed.
Slice     1: Simulation  40% completed.
Slice     1: Simulation  50% completed.
Slice     1: Simulation  60% completed.
Slice     1: Simulation  70% completed.
And it still works in single-thread. Is there any way to solve this problem?
soliday
Post by soliday » 10 Jan 2020, 16:14
There were multiple problems with GENESIS built against the current SDDS source code tree. I think I fixed all the problems. I have put up a new link to the source code and updated the date. Let me know if this works for you.
yiding
Post by yiding » 11 Jan 2020, 20:45
Thanks for your kindly help.
It seems the Makefile in the download link hasn't changed yet, and it still doesn't work.
I copied the new makefile you posted in this topic, and made genesis_mpi seccessfully, but it does not
work correctly in multi-threads, and gives the same error message as I posted last time.
It seems the program has a problom in reading input files when it runs in multi-threads.
yiding
Post by yiding » 11 Jan 2020, 21:25
Sorry. I've made a mistake. I downloaded the old version.
Now I refresh the firefox cache and download the new codes.
When I compile the new codes, there comes an error message as:
Code: Select all
$ make MPI=1
 ******* moving correct mpi.f file into place ******
mpif77 -g -w -O -Wall -m64 -O2 -ffixed-line-length-132 -Wall -fno-second-underscore -Wno-unused -o GENESIS_mpi main.f check.f diagno.f esource.f field.f incoherent.f math.f partsim.f pushp.f loadbeam.f loadrad.f magfield.f tdepend.f track.f string.f rpos.f scan.f source.f stepz.f timerec.f initrun.f  input.f output.f mpi.f sdds.f /home/fermion/epics/extensions/src/SDDS/fortran/O.linux-x86_64/fortran_wrapper.o -L/home/fermion/epics/extensions/lib/linux-x86_64 -lSDDSmpi -lrpnlib -lmdbmth -lmdblib -llzma -lz -lgsl -lgslcblas -lc
/usr/bin/ld: cannot find -lSDDSmpi
/usr/bin/ld: cannot find -lgsl
/usr/bin/ld: cannot find -lgslcblas
soliday
Post by soliday » 13 Jan 2020, 12:09
SDDSmpi is built in epics/extensions/src/SDDS/SDDSlib
You have to run "make clean ; make MPI=1" in this directory.
As for the gsl library, try removing "-lgsl -lgslcblas" from the Makefile and see if it links without those libraries.
yiding
Post by yiding » 16 Jan 2020, 06:49
Thank you very much!
It works! :D
Post Reply
