I am trying to run "boosterramp" sample file which I also attached. It did not work on windows and I tried to run it with cygwin; and to be sure that cygwin and elegant works well, I tested it with twis calcularion and having plot, it works. so I am sure that cygwin and elegant is there and working well.
hovewer, when I start to run boosterramp file, I had a problem as I explained below;
I am doing what it writes in "notebook" document which is also attached;
- I write "elegant BYBL0.ele" to the command line ant it gives a twi file as an output.
- Hovewer, when I write "computeRfRamp -twiss BYBL0.twi -momentum MagRamp.sdds=time+momentum -output RfRamp.sdds -Vmax 1.2 -harmonic 264 -overVoltage 1.5 -Vped 0.25" to command line, it gives an error and writes; "there is no oagtclsh".
I would appreciate if you could help me to figure it out.
cygwin and oagtclsh error
- Attachments
- boosterRamp (1).zip
- (40.55 KiB) Downloaded 789 times
Re: cygwin and oagtclsh error
There is file installed with OAGTclTk called "Windows Instructions.txt" that explains what you need to do to get this to work. Try running:
tclsh computeRfRamp -twiss BYBL0.twi -momentum MagRamp.sdds=time+momentum -output RfRamp.sdds -Vmax 1.2 -harmonic 264 -overVoltage 1.5 -Vped 0.25
If that doesn't work, try running:
c:/Tcl/bin/tclsh computeRfRamp -twiss BYBL0.twi -momentum MagRamp.sdds=time+momentum -output RfRamp.sdds -Vmax 1.2 -harmonic 264 -overVoltage 1.5 -Vped 0.25
Hi Soliday, thank you for your effort but it did not work unfortunately.
When I write "tclsh computeRfRamp -twiss BYBL0.twi -momentum MagRamp.sdds=time+momentum -output RfRamp.sdds -Vmax 1.2 -harmonic 264 -overVoltage 1.5 -Vped 0.25" to command line, it says;
no such variable
(read trace on "env(HOST_ARCH)")
invoked from within
"linsert $auto_path 0 /usr/local/oag/apps/lib/$env(HOST_ARCH)"
invoked from within
"set auto_path [linsert $auto_path 0 /usr/local/oag/apps/lib/$env(HOST_ARCH)]"
(file "computeRfRamp" line 5)
and when I write "c:/Tcl/bin/tclsh computeRfRamp -twiss BYBL0.twi -momentum MagRamp.sdds=time+momentum -output RfRamp.sdds -Vmax 1.2 -harmonic 264 -overVoltage 1.5 -Vped 0.25", it says;
can't read "env(HOST_ARCH)": no such variable
while executing
invoked from within
In the meantime, I kept my effort to sort it out in another way;
- I tried to run it on cygwin as you suggested, I run Build-OAP-RPMs file and I have chosen "Yes" the first 4 selection between the download choices and "no" for the rest. At the end it gaves an error like;
Building SDDS RPM package. This may take a minute.
grep: /etc/passwd: No such file or directory
while executing
"exec ./rpmdev-setuptree"
("eval" body line 1)
invoked from within
"eval exec $sudo ./rpmdev-setuptree"
invoked from within
"if {$Build(SDDS)} {
puts "Building SDDS RPM package. This may take a minute."
eval exec $sudo wget -q http://www.aps.anl.gov/asd/oag/down...
(file "Build-AOP-RPMs.tcl" line 1108)
Do you help me how I can figure it out?
özgür
no such variable
invoked from within
invoked from within
while executing
invoked from within
while executing
invoked from within
invoked from within
özgür
It sounds to me like you don't have OAG_Tcl-Tk installed on your computer. When you install this, it sets the HOST_ARCH variable and installs the needed files to run our scripts.
You will need ActiveTcl from:
http://downloads.activestate.com/Active ... readed.exe
Visual C++ 2013 Redistributable for Visual Studio 2013 from:
http://www.microsoft.com/en-us/download ... x?id=40784
OAG_Tcl-Tk from:
http://www.aps.anl.gov/asd/oag/cgi-bin/ ... Tk-x64.msi
The Build-AOP-RPMs script is only for linux and won't work on Windows.
OAG_Tcl-Tk from:
